Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-15-2016, 02:27 PM
kimper kimper is offline
2002 Corolla weird idle
I have a 2002 Corolla automatic with 231807 miles on the body and transmission and just over 100000 on a head I had rebuilt due to oil consumption. I parked for about a year and now am driving it 125 miles a day to work and back and have a idle issue where when I start it (I live in Minnesota so it's like -degrees right now) when it's cold the car doesn't want to idle, but once it's warmed up it idles at like 1400 Rpms. I have no CE light and am curious if it sounds like a IAC sensor or not. Any info would be awesome..
Old 12-15-2016, 08:34 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2002 Corolla weird idle
Check your engine coolant temperature sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-16-2016, 02:22 PM
Wouldn't that throw a CEL if it was bad?
I looked into it a little more last night and unplugged my Idle air control sensor while it was cold and running and it didn't seem to effect anything so Does that tell me anything?
Old 12-16-2016, 07:21 PM
Brian R.'s Avatar
Resident Chemist
No, there is no signal that your ECT sensor is bad. Your ECM always assumes that the signal from the ECT is correct. If it's not, the ECM makes your mixture wrong and you will run weird.
No, it doesn't tell me anything.
Old 12-17-2016, 10:22 AM
Ok, thanks for the info. I will try that today
Old 12-26-2016, 05:20 PM
I just replaced my coolant temp sensor and thermostats and my idle hasn't changed. Anyone have any other ideas?
Old 12-27-2016, 11:01 AM
somick's Avatar
somick somick is offline
How about your throttle body?
Has it ever been cleaned?
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
