2000 Mercury Villager
I have a 2000 mercury villager mini van it will turn over but want start. Its not getting any fire to any of tje spark plugs I just now replaced the distributor and still nothing
Re: 2000 Mercury Villager
You should post this in the Mercury Villager forum. You may have better luck. Why did you replace the distributor? You said no spark. Check voltage to the distributor.
Post back, that's what makes Forums Work. |
First of all, the problem could be something as simple as a weak battery. Modern electronic ignitions require a LOT of electrical power to start and run. Just because the engine will 'crank' does not necessarily mean that the ignition system has enough power to fire the sparkplugs. If you have a known-good battery from another car that will fit in your battery box, I'd try swapping batteries first.
Past that, I'd guess that the two most likely components to fail would be the coil or the crankshaft position sensor. An OBD II scan would probably give you the answer. Otherwise, I'd recommend having the van towed to the dealer or a reputable technician and have the ignition system tested instead of spending more money replacing parts that may or may not be working. There's one other common problem that could cause the van not to start - a broken or damaged timing belt. However, this problem doesn't usually cause the spark plugs not to fire... I do wish you good luck! Dave B. |
