Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-12-2016, 07:30 AM
dskap dskap is offline
Upper steering shaft replacement
How difficult is it to replace the upper and lower steering shafts on a 2001 Crown Vic?
I got the parts ordered but cannot find anything as far as instructions on how to replace and any tips on do's and do not's
Any replies are greatly appreciated.
Old 12-12-2016, 12:47 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Upper steering shaft replacement
The upper shaft on the '01 will connect to a U-joint on the steering column, under the dash. Another U-joint is on the intermediate shaft that connects to the lower shaft under the hood. This is collapsible, meaning that it can be shortened. Remove the bolts on each end of the shaft and collapse it down to remove it. There should be a flange at the firewall that you will need to remove.
The lower shaft is attached to the steering gear via a 'rag joint', remove a bolt connecting the lower part of this rag joint to the steering gear, pull it off and it's removed. Assembly is the reverse of disassembly.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-12-2016, 07:45 PM
Thank you ever so much and WOW did you respond fast to my question!
Hoping you and yours all have a most wonderful holiday season!
Old 12-21-2016, 05:32 AM
Hello again,
I just got the upper and lower shafts and will be installing today or tomorrow.
I should have asked last time but didn't think of this....Can you please tell me if there is a certain torque ft.lbs. for the bolts that connect the upper and lower shaft and to steering column?
Also, should I use blue Lock Tight on all the bolts?
Thank you ever so much again for your help!
Dan
Old 12-21-2016, 10:04 AM
Originally Posted by dskap View Post
Hello again,
Dan
UPDATE:
I just finished. Tightened everything up REAL good with Lock-Tite.
Very difficult getting the old off as everything was really rusted big time.
Now, I have a nice new steering shaft and you guys helped so much.
Thank You once again and may you all have a wonderful Holiday Season and a great New Year!
Dan
