Old 12-04-2016, 09:00 AM
solarkowboy solarkowboy is offline
Z71 dashlight problem
has anyone else had problems with the dash lights not working at night and working during the daylight. at night when dash lights are out i can push dome lite switch 4 times and everything reverses. headlights go out and dash lights work again. the transmission lights and dimmer light work all of the time when key is on.
Old 12-05-2016, 07:54 AM
j cAT j cAT is offline
Re: Z71 dashlight problem
the headlight switch dimmer assy is defective. common esp. if after market type stuff uses the dimmer switch .. the shift indicator is different circuit.
Old 12-05-2016, 12:04 PM
don't have anything aftermarket installed. dimmer works just fine. does dome lite tie to dimmer switch?
Old 12-05-2016, 12:08 PM
chevy dealer says it's the BCM(body control module). 600.00 for part 400 labor. think i'll try other things first.
Old 12-05-2016, 12:24 PM
aleekat aleekat is offline
He didn't say after market stuff made the dimmer switch go bad. Just that it could. I'd go with replacing dimmer switch.
Post back, that's what makes Forums Work.
Tags
dashlight , problem.
