Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-29-2016, 06:35 AM
deerefeed deerefeed is offline
Rear washer pump location?
Where is the rear washer pump located? Mine has stopped pumping and winter is coming when I need it most. I need to look into this.
Old 11-29-2016, 07:48 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Rear washer pump location?
Well- if you think about it, there is only one reservoir for windshield washer fluid- at the bottom is always the pump attached to the reservoir for the front- so obviously, the rear would also be attached to the same reservoir- the trick is to know which is which- so trace the hoses, or swap the hoses to make sure the rear not washing is the fault of the pump, and not a leak somewhere, or plugged up spritzer nozzle... I use a tag wire to clean out nozzles..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-29-2016, 06:07 PM
LMP's Avatar
LMP LMP is offline
Yes, both pumps are together on the side of the reservoir.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
The Following User Says Thank You to LMP For This Useful Post:
deerefeed (11-30-2016)
Old 12-28-2016, 09:54 PM
A few taps on the side of the pump with the switch on and away it went. It lives another day.
