Old 11-28-2016, 08:37 PM
Lmh1975 Lmh1975 is offline
200 ford Taurus transaxle
I have 2001 ford Taurus se with 158000 but with rebuilt tranny. Transaxle light and engine light r both on. Engine light codes r for shift sensors didn't know u could get tranny codes as well. But anyway...my car slips between first and 2nd gear but more when I turn left or am going uphill from a stop. Handles hills and turns ok if I can keep it above 30 miles an hour and as long as u don't punch it from stop lights it shifts as it should goin straight and on right turns. Car just does not like left hand turns at all. Can anyone tell me what it may b?
Old 11-29-2016, 05:08 PM
MikeCStig MikeCStig is offline
Re: 200 ford Taurus transaxle
I'm sorry to tell you that you have a car that is known for transmission problems. The Ford Taurus from that generation (excluding the SHO models) go through transmission failure quite often. The symptoms your describing are where it usually starts and it's just going to get worse. The best part of your car is the engine, the rest of it is either just mediocre or just plain crappy.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
