Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-26-2016, 06:44 AM
jnybob jnybob is offline
95 Buick Regal misfiring
My Dad's 95 Regal has a problem. It idles great, but when the tranny is moved to D or R, it starts misfiring bad, the car jerks and shakes. Any ideas? Thanks in advance for your time.
Old 11-26-2016, 01:28 PM
maxwedge maxwedge is offline
A990 racer
Re: 95 Buick Regal misfiring
Pretty general description, any check engine lite? Good wires and plugs?
Old 11-26-2016, 06:08 PM
Sorry, No check engine lights, plugs and wires have been replaced. Dad's mechanic told him the coil packs were ok. The engine does not backfire, just runs really rough. Again, this only happens when it is in gear. I had the same problem with a 97 Bonneville, except the problem was intermitent. Finally after replacing all three coil packs the problem disappeared. I am still suspicious of the coil packs, but I am not a trained mechanic. Thanks for your time.
John
Old 11-26-2016, 06:26 PM
A990 racer
Could be something is grounding out with a wire or sensor connector, recheck the plug wires for proper routing and connections.
Old 11-27-2016, 09:42 AM
Will check wires. Thanks for your time.
John
Old 11-28-2016, 05:12 PM
MikeCStig MikeCStig is offline
I'd be suspicious of the coil packs too. Get those checked. If they're bad that might be the answer to your problem. If you get the coil packs checked and they're ok, it would be time to check your fuel system. Is the fuel pump working Right? Are the fuel lines ok? When was the last time the fuel filter(s) was checked and/or replaced? Are the fuel injectors clogged? These are all questions you'll have to find the answer to if the coil packs aren't the problem. Keep posting, let us know how it goes, and good luck.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
