Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 11-25-2016, 10:00 PM
smantas smantas is offline
digital temperature gauge and cooling system
I have a 2001 grand marquis with a digital dash. After letting the car idle in 40 degree outside temps with the hood up the cooling fan kicks on ...meanwhile the digital temp gauge never gets off the 3 bar mark...when the fan kicks on it knocks it back down to 2 bars and continues this cycle...is this normal?..
also the antifreeze is a brownish color, no oil in it, no white smoke and the oil looks clean...
I just bought this car and it was maintained by the dealer since new from some old man original owner...
Every ford I have ever owned the temp gauge always stays in the middle...both analog and digital...
havent driven the car yet except for the 3 mile drive home since I bought it. is this something that needs to be driven to get it to the 4 bar mark?...obviously it's up to operating temp if the fan is kicking on and off and the upper radiator hose is hot so I know the thermostat is open...also hose is not rock hard so I have eliminated a bad head...thoughts?
Old 12-01-2016, 06:22 PM
Re: digital temperature gauge and cooling system
anybody ?
Old 12-02-2016, 11:25 AM
auto trainy auto trainy is offline
How many miles?
Old 12-03-2016, 12:23 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
First, I would do a full flush of the cooling system and use new antifreeze. Use the yellow kind.
Also, it is possible the thermostat has been removed from the car. Are you getting a check engine light?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-03-2016, 08:47 PM
Has 142000 miles ...no check engine light and thermostat is still in car and working properly...Car calls for the conventional green..
