Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 11-25-2016, 03:15 PM
Raymond M Raymond M is offline
Send a message via AIM to Raymond M Send a message via MSN to Raymond M
94 Villager check engine light
My villager is seldom driven but I need inspection to register. I bought new and have driven 124,000 and spent a small fortune on small to large repairs mostly minor. In past check engine have been easy to fix. This time however, with the help of AutoZone doing the code check, the code is 51 - fuel injector. I think I know how to find the offending injector but replacing it is an issue for me. The costs may be more than I am willing to pay. Any idea as to how much this would cost. The code 51 was the only one.
I have read that others with the same problem have replaced injectors only to have another fail a few weeks later, on and on. I hate to "clunker it out" because it is a great running car and in fairly good shape, specially the interior, AC, battery and tires.
Old 11-28-2016, 06:30 PM
MikeCStig MikeCStig is offline
Re: 94 Villager check engine light
That's why when you're replacing fuel injectors you shouldn't just replace them one at a time. If changing out fuel injectors, do them all at once.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 11-28-2016, 11:39 PM
Replace them all is a great idea but at $80 each for 6....whew!
Old 11-29-2016, 03:35 PM
It's better than playing wack-a-mole with each injector individually as they fail.
