Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 11-10-2016, 09:43 PM
CarloITA CarloITA is offline
Bearing hub torque specs
Hallo again,
you couldn't help me with my first thread, let's see if I'm more lucky here with my other question:
Oldsmobile Silhouette 2004 FWD, I need to replace the bearing hub of the front wheel but I can't find the specs for the torque of the three bolts that attach the hub to the suspension.
I could easily find the axle nut specs 160Nm but no luck with those three bolts.
And what about the torque of the bolts of the caliper?
I wish I could find the original workshop manual for my car... I can only find aftermarket ones...
any help?
Thank you
Old 11-11-2016, 08:25 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Bearing hub torque specs
Originally Posted by CarloITA View Post
Hallo again,
any help?
Thank you
Three retaining bolts...96 Lbs Ft (130Nm)
Caliper bracket bolts...137 Lbs Ft (185Nm)
Caliper bolts...40 Lbs Ft (54Nm)
Old 11-11-2016, 09:40 AM
Thank you so much
