Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-08-2016, 02:13 PM
CALL ENDED CALL ENDED is offline
Noise in steering wheel
2004 LS V6. I have the telescoping steering wheel when I get into the seat and start the car the steering wheel moves into position when it moves up and down it makes a noise as if something is grinding it's not the plastic housing around the column it seems to be in the neck. Any ideas
Old 11-10-2016, 10:26 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Noise in steering wheel
I'm not sure what be likely to cause that noise, but in the mean time I would suggest you turn off the "Easy Entry" feature so that you don't end up with a steering wheel that cannot get in the comfortable and safe position of your liking.
-Rod
Old 12-18-2016, 06:48 AM
How do i turn that off?
Old 12-18-2016, 10:10 AM
shorod's Avatar
SHO No Mo
You should be able to select that through the driver information center in the instrument cluster. If you don't have an owner's manual to see details on how to disable it, you can download a PDF of the manual from here.
-Rod
Old 12-18-2016, 11:12 AM
Thanks
