Old 11-06-2016, 07:01 PM
sprite46cfk sprite46cfk is offline
Decaling Advice Needed
All - I recently sprayed a body with decanted Tamiya lacquer. The finished body had some light orange peel and a few dust bits so I went over the entire finish with Micro Mesh polishing cloths up to 8000 grit. Orange peel and dust particles are now gone and finish is very smooth.
My question is: Can I apply decals to this smooth 'flat finish' body before I apply the clear coat? Or should I add a couple of coats of clear and then decal and clear again?
I know decals over a flat finish is a no-no, but does the polishing cloth sanding process make a differences for decal application?
Thanks in advance,
Chuck
Old 11-07-2016, 02:51 AM
CFarias's Avatar
CFarias CFarias is offline
Re: Decaling Advice Needed
Personally, I've never had an issue with silvering under the decal when I've polished only up to 4000 grit so 8000 grit should be not problem.
Sometimes the decals won't set well on polished surfaces but at 8000 grit that shouldn't be a problem. Rougher surfaces, such as 4000 grit or lower sometimes will not provide the decals enough surface to stick to, which will make it more likely to come off when the decal dries. Using a setting solution under the decal will help prevent this.
Hope this helps.
Old 11-07-2016, 03:52 PM
stevenoble's Avatar
Is the surface still shiny/smooth, or is it totally flat with no shine whatsoever? If it has that flat milky white look then there is a possibility that when you apply the decals the milky look could show through the clear decal film. Personally I would use a little rubbing compound and restore the gloss before adding the decals. Just enough to remove the sanded look and be safe.
Steve Noble
Old 11-07-2016, 11:03 PM
Niro750 Niro750 is offline
If you use a polishing compound make sure to thoroughly wash it off.
Decals won't be like adding more paint, you want a nice smooth surface not a keyed one.
Old 11-08-2016, 06:27 PM
Thanks guys for your comments. I've decided to polish the body to restore some gloss and then add decals and finally clear.
Chuck
Old 11-13-2016, 07:32 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Instead of polishing, another option is just to spray another very light coat of well thinned body color. You are using Tamiya lacquer thinner in your decanted TS color, aren't you? Add even more, turn down the pressure on your compressor regulator a bit, and just lightly dust on one last coat of color. Much easier and faster than bothering with a regimen of sanding, and it leaves a surface ready for decalling.
PHOTOBUCKET SUCKS
The Following User Says Thank You to MPWR For This Useful Post:
sprite46cfk (11-13-2016)
