Old 11-06-2016, 06:07 PM
rubberman rubberman is offline
Power steering issue
Started the GP and was turning the steering wheel which was hard to turn. It then began to whine loud when turn left and right. Looked under car and it dumped a lot of fluid on the driveway. I couldn't find the leak but I filled it back up with power steering fluid and it's not leaking that I see. It's not making the whining sound when turning the wheel. Thoughts?
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 11-07-2016, 11:43 AM
DrRadar DrRadar is offline
Just a guy
Re: Power steering issue
My guess is there is a leak on high pressure side that opens only when pressure is high and in certain positions. For example, flexing in the line might squeeze as cracked hose shut in some positions (no leak) and open in other (leak). Temperature may also influence leak vs. no leak. Likely suspect is high pressure line but could be pump or possibly low pressure hose.
Try wiggling hoses with engine running and warm and wheels in various positions. Take care not to get burn... Wear gloves and consider uses a tool to do reaching and moving.
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
Old 11-07-2016, 12:00 PM
Must be. I refilled it and drove 22 miles to work. Sat in parking lot turn wheel left to right and not one drop on the ground. No pump whining either.
Old 11-11-2016, 10:41 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Inspect the return line/cooler assembly too. When the crimped fittings between the metal and rubber sections fail, they will start to suck air. It won't leak on the ground because it's on the suction side, but it will cause the fluid to start to foam. Each time you park it the foam dissipates and air is trapped. When enough air gets trapped, it gets forced through the lines compressed. When that happens, the fluid will puke all over the place, and over time after re-filling, it will happen again.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
The Following User Says Thank You to richtazz For This Useful Post:
rkvons (01-01-2017)
