Go Back   Automotive Forums Car Chat > Nissan > Rouge
Old 11-04-2016, 12:45 AM
sellanycar sellanycar is offline
Rotors always replaced with pads?
I have a 2011 Nissan Rogue with 86,000 miles. I'm told my pads are at a 2.7 and I need new brakes. Two shops I've called tell me the rotors are replaced at the same time. Im looking at about $350 for the front and $300 for the rear. Do you agree rotor replacement is a given or am I being taken? I'm not experiencing any braking issues. Thanks
Old 11-04-2016, 05:07 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Rotors always replaced with pads?
There is no need to replace rotors just because you are replacing pads, unless the rotors are out of spec, or causing a thumping brake pedal.
Old 11-04-2016, 02:12 PM
MikeCStig MikeCStig is offline
Rotors only need to be replaced if you've let the pads go for too long and as a result the rotors are warped. Even then, sometimes the rotors can just be resurfaced. If a mechanic tells you that your rotors are warped, always get a second opinion, especially if the car doesn't get all shaky when you hit the brakes. Warped Rotors are often used as a scare tactic by greasy shops to get you to buy more sh*t that you don't actually need.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 11-04-2016, 06:21 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
they will be worn down some and will have some small groves in them. depends how thick they still are and if they will still be within spec after surfacing. often they just say to replace them to save them the job of machining them. they usually run about $35-60 each for new
Tags
braking , issue , nissan , repair , rogue
