Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-03-2016, 09:46 AM
Brandonhouda Brandonhouda is offline
please help 95 4runner lost all power
please help! Went out yesterday and started my truck to warm it up and turned on running lights, came out 5 min later and passenger side front and back running lights were off. originally thought fuses but checked all and all were good. today went out to start truck and when i turned the key and click.... all power was gone!! thought I left a light on and battery died. but tested battery and all is good and not dead! was able to jump truck from wifes car but after letting it run and drove a little bit, turned it off and when i tried to turn it back on same thing! i noticed when driving that the stereo turned off and on a couple times acting like it was loosing power. not sure if these two things have anything to so with each other but seems like they might! I have read a couple other forums and saw that some were saying check the cable coming off the positive terminal into the fuse box? any suggestions would be great! I love my truck and want it back! please help!
Old 11-03-2016, 09:56 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: please help 95 4runner lost all power
make sure your battery connections are good and clean and tight. also if you have a voltmeter check battery voltage while running, should have around 13.5-14 volts at idle. your alternator might be worn out. if you dont have a voltmeter you can take car or alternator down to your local parts store. most will check battery and alternator for free
Old 11-04-2016, 10:10 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Please don't post in more than one thread....
Read the other thread too.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Tags
1995 , 4runnner
