Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-02-2016, 08:39 PM
famlycar famlycar is offline
brakes lockup and loud hum at 50mph just after new tires
hello again.
I thought I had this problem fixed by greasing the caliper pins but no, the problem came back about a week later and has been doing it ever since only when I bought new tires. could the tires be bad even if they are new?
this is a strange one. I had the bearings checked and they are good. I bled the brakes and this helped the lock up issue for now but the loud hum is still there.
Help!
Old 11-03-2016, 06:15 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: brakes lockup and loud hum at 50mph just after new tires
It could be bad tires, but I bet with the brake issues you are having an ABS issue. Maybe a harness got damaged or unplugged when they had your tires off.
Old 11-03-2016, 07:39 PM
I don't have abs. The brakes locked up on me again today so bleeding them didn't stop the problem.
Old 11-04-2016, 12:13 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
sounds like you might have calipers or wheel cyl frozen up
Old 11-05-2016, 06:00 PM
Thanks. one thing I forgot to mention is the brake adjuster on the drivers side rear won't adjust very far to get the wheel on as the other side does.
I had to squeeze the shoes together to get the drum on. also my calipers have never been replaced but are very clean especially when I lubed the pins in there.
My e-brake I had to loosen all the way as it has something to do with the lock up I think. Also, It only locks up in the afternoon and never in the morning if this helps.
it's a strange one!
Old 11-06-2016, 09:10 AM
Crvett69's Avatar
the springs should hold the shoes together, if not they are shot or there is something wrong in there, sounds like you need to replace the adjuster or take it apart and grease it, sounds like time for a rear brake rebuild with new hardware kit and at least 1 adjuster.
Old 11-06-2016, 11:20 AM
ok, I removed that same rear wheel and the drum came off easily and the springs and adjuster appear ok I guess but the adjuster should be replaced you say. the shoes are still good and the drums I replaced last month thinking this would help. I cleaned the area with brake cleaner before doing so.
My front calipers I checked last month and they appeared ok.
Old 11-11-2016, 09:39 PM
ok, I replaced that adjuster screw on the driver's side rear brake and those springs and pins as well. The car is not locking up on me anymore as it has been almost a week with no problems. Thanks.
Now I have to find out what is causing the front end to shake at 60+ mph?? It does it when in both drive and neutral if this helps.
Old 11-16-2016, 08:55 PM
Ok, I'm slowly learning that the tire shine product had a lot to do with messing up my brakes after all. This stuff is definitely not good for moving parts. This very sticky stuff ended up getting on my brake parts as well as attracted a lot of dirt on my tires making it very hard to wash off later. The tire store didn't even ask me if I wanted it or not. First time I ever had this stuff sprayed on my tires at any tire store. First they spray it all over and then spread it on with a rag. I'm beginning to realize over time that the only one who can repair and take care of an automobile properly is the owner himself and this includes installing tires. It's a real shame.
Old 11-16-2016, 09:09 PM
Stealthee's Avatar
I honestly think you are grasping at straws with that one. I use tire shine all the time and have never had one issue with brakes.
