Old 10-19-2016, 04:04 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
tailgate won't latch
In order for me to close the tailgate, I have to pull on the tailgate release lever with my right hand and then it will let me move this little piece with my left hand, then close it. If I don't do that, this piece (by my finger) hits and won't let it close
This ain't your grandma's car!!
Old 10-19-2016, 05:42 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: tailgate won't latch
Grease it.
Old 10-21-2016, 12:57 PM
phipps phipps is offline
Clean it real well with something like WD40 and after its dry, lube it.
Old 10-24-2016, 06:40 AM
rhandwor rhandwor is offline
If cleaning doesn't work try a trip to a junk yard.
Old 10-24-2016, 06:42 PM
gw84's Avatar
for a whole tailgate or can I replace just that little piece?
Old 10-24-2016, 09:18 PM
You would have to replace the whole latch.
Old 10-25-2016, 06:58 AM
You need to call a few yards with year,make,model of your truck. Hope fully they have a tail gate with a small bend in it and they will allow you to remove what you need. My 2000 Chevy had a rod from each side and a plastic clip broke. I purchased two new clips on ebay cost around $12.00.
Old 11-15-2016, 06:07 PM
gw84's Avatar
small bend? As in the tailgate isn't suitable for use so they wouldn't care if it were used for parts? Does the tailgate come apart to replace the inner workings?
Old 12-01-2016, 04:58 PM
gw84's Avatar
bump. I'm looking through videos on youtube (which solved a couple of my silverado problems), but all I can find in relation to repairing the tailgate are videos about replacing the handle which is obviously a common problem. My handle is fine, it's the little piece in the picture above that I need instructions on repairing. thank you
Old 12-01-2016, 06:19 PM
j cAT j cAT is offline
the tail gate has 2 pins. those pins are adjustable . move the pins out of the bed area toward the tail gate. I think its a torx bit required to loosen and move them.. over time they get pushed into the bed area and then no latching I had to do it .
