Old 07-02-2003, 07:11 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Hubs sizes ?
I just bought some drilled and grooved discs and some 1.6 calipers off of Civic91,
now i want to know wether the discs will fit onto my 1.3 or will i have to change the hubs for them to fit?
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 07-02-2003, 08:04 AM
EF6_CR-X's Avatar
EF6_CR-X EF6_CR-X is offline
They will fit as long as you have all the caliper mounting parts, but you will probably need a larger master cylinder to make up for the extra displacement of the caliper pistons (you will most likely end up with a low or soft pedal)
Are the Calipers and Discs from a 1.6-16V or a 1.6-VT?
the 16V ones will be fine but the VT ones won't fit without the knuckles.
Old 07-02-2003, 08:06 AM
Civic Jim's Avatar
they r off a 1.6 16v, all i bought was the calipers and discs nothing else, will they bolt straight on
B16A1 I/H/E
4TH GEN UK SITE
Old 07-02-2003, 08:16 AM
EF6_CR-X's Avatar
they should fit, it will only take you about 1/2 an hr to test fit one side, without disconnecting brake lines etc..
Old 07-02-2003, 08:20 AM
Civic Jim's Avatar
ah right ok cool, cheerz m8
B16A1 I/H/E
4TH GEN UK SITE
