Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-13-2016, 01:47 PM
Chaunse Chaunse is offline
Fuel issues
Hi guys I have an 02 sc1 where that's not getting fuel. The security light is on but the pump is not working. I have replaced the pump, the relay and fuse. Is the security causing the issue? From what I've read the pump should still kick on. Any help would be appreciated, thank you
Sent from my SM-S920L using Tapatalk
Old 10-13-2016, 09:05 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: Fuel issues
Passlock disables the fuel injectors, but the fuel pump should still run. Check the 10A BODY fuse in the interior fuse block. If that fuse is blown or removed, power mirrors, power door locks, and the dome lights (and map lights if you have a sunroof) also won't work.
If that checks out fine, check all PCM-related fuses in the underhood fuse block. If those are good check for power at the relay and fuel pump, and check the ground going to the fuel pump.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
