Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 10-07-2016, 07:01 AM
Amberayden Amberayden is offline
Angry 97 expedition wont start
so... my 97 expedition just wouldn't start after just driving it it has a new ac compressor new serpentine belt new starter solenoid battery giving off power needed. litterally had the truck running for a day before adding the starter solenoid (put on last night to see if that was the problem) truck has power, when i turn my key over and hit my kill switch it still will not start what else could be the issue?
Old 10-07-2016, 09:05 AM
Unhappy Re: 97 expedition wont start
please some one answer i need help
Old 10-07-2016, 09:53 PM
65comet's Avatar
65comet 65comet is offline
I am going to assume that you are cranking the starter and it is turning over the engine at a good speed, but there is no sound of the engine beginning to spark and fire? An engine needs 3 things to run, air/fuel/ignition. I would hook up a OBD-II reader and look for codes. If the CEL (check engine light) isn't on to indicate a code to help show where the problem is (some problems need the engine having run to set them), I usually start with the simplest then. I would open up the air cleaner and give one shot of starting fluid into the intake past the air filter and try to start. If the engine tries to fire from the starting fluid, then you know your problem is fuel related and you can trace your problem in that direction. If it isn't that, then I would pull out a spark plug and test to see if it is sparking during cranking (search youtube for video on how to do that). If it isn't sparking, then you have an electrical issue and can head in that direction.
Old 10-08-2016, 06:38 AM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
If it is not turning over, then you might want to check your transmission switch-- most vehicles won't allow you to start the vehicle when the transmission is not in Park.
Try bumping the shift lever toward the Park position and see if that makes a difference.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
Old 11-09-2016, 07:26 AM
rhandwor rhandwor is offline
Try in neutral and check if it will turn over. Check battery connections and ground.
