Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-01-2016, 03:37 PM
wayneo70 wayneo70 is offline
Unhappy help!!!!!!
i have a 2002 bravada smart track awd can i remove the drive shaft that goes to the front and remove both cv's without and damage being done
Old 10-01-2016, 08:24 PM
maxwedge maxwedge is offline
A990 racer
Re: help!!!!!!
Do you mean drive it that way?
Old 10-01-2016, 08:42 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: help!!!!!!
I know you can't with the Borg-Warner AWD transfer case w/viscous clutch (which were also installed on some Explorers and Mountaineers) but I don't know about the encoder motor activated ones on the '98 and newer Bravada.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-03-2016, 12:07 PM
Re: help!!!!!!
Yes I want to drive it that way
Old 10-03-2016, 06:13 PM
A990 racer
Re: help!!!!!!
That will not work with a computer controlled transfer case.
