Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-30-2016, 01:21 AM
Fuzzy1952 Fuzzy1952 is offline
Code PO405
Need help. Check engine light on. Replaced EGR, new ECM (flashed) and still getting code. Thinking electrical. Is there an electrical wiring diagram for the EGR ? Car needs inspecting. Thanks.
Old 09-30-2016, 08:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Code PO405
What year Bravada?
Here's some info,
http://www.fixya.com/cars/t12918939-code_po_405
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-30-2016, 08:38 PM
Re: Code PO405
The car is a 2000 Oldsmobile Bravada with a 4.3.
Old 10-01-2016, 09:12 PM
AF - Advisor
Re: Code PO405
All I keep seeing is to check the wiring and connectors from the EGR valve back to the computer.
The Following User Says Thank You to Chris Stewart For This Useful Post:
Fuzzy1952 (10-01-2016)
Old 10-01-2016, 11:55 PM
Re: Code PO405
Thanks Chris for your help. Taking the car tomorrow to someone with electrical experience in cars. Praying for no codes so the car will pass NYS inspection.
