Old 09-29-2016, 04:45 PM
tuffy65 tuffy65 is offline
no brake lights
2001 windstar I have no brake lights and also some times its hard to get in to gear the shifter wont move usually I can get it to work by tapping on the fuse box playing with the key or playing with the shifter.
Old 10-01-2016, 04:20 PM
Re: no brake lights
fixed the brake light problem it was the brake light light switch. Now we will just have to see over time if it also fixed the shifter problem or not.
Old 10-07-2016, 08:04 AM
phil-l phil-l is offline
Re: no brake lights
The brake light switch (which is under the dash and attached to the brake pedal assembly) does seem to fail over time (mine slowly died; it left the brake lights on once, draining the battery). It's fairly cheap and easy to replace.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 11-12-2016, 04:04 PM
wiswind wiswind is offline
Re: no brake lights
Brake switch will also keep you from shifting out of park.
FIRST the wire to my brake switch broke.....
Second....my brake switch failed.....It would work when you pressed the brake pedal....but if you let up just a slight bit.....the brake lights went out.
It took someone following me (a group of vehicles traveling together) telling me about it in order for me to know.....after we checked them and they were working fine.....they noticed that they would flash ON....and go back out.
This is because you normally press the brake and then let up a bit.
New brake switch solved the problem.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
