Old 09-27-2016, 07:30 PM
buickultra2000 buickultra2000 is offline
2000 Ultra Tune-Up - Loosen Motor Mounts
The shop I called said they had to charge more for a tune-up because the 3800 engine requires loosening the motor mounts. Is this true? Thank you.
Old 09-27-2016, 08:01 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
Re: 2000 Ultra Tune-Up - Loosen Motor Mounts
Yes, the mounts need loosened and the engine rocked forward to do the rear plugs on a 3800.
Old 09-28-2016, 07:50 AM
maxwedge maxwedge is offline
A990 racer
15 minutes work.
Old 09-28-2016, 08:45 AM
STEALTHEE and MAXWEDGE: Thank you!!
The Following User Says Thank You to buickultra2000 For This Useful Post:
maxwedge (09-28-2016)
Old 09-28-2016, 09:43 AM
Tech II Tech II is offline
No, it doesn't....
Old 09-28-2016, 06:40 PM
A990 racer
Well after the engine is rolled toward, (easy part), it is still tough to get the plugs out.
Old 09-28-2016, 07:04 PM
Blue Bowtie's Avatar
Registered Offender
I'm with T-2. The rear plugs can be done without moving the engine, even in a little old J-body or something smaller. The LeSabre/PA is cake. Been there, and been there, and been there, and... Well, you get it. It isn't like a 3L Fjord V-6 where the intake has to be pulled to get the rear plugs. They're sitting right there where anyone over 5' tall can reach them easily, from 1991 until the end of the run.
Old 09-28-2016, 10:07 PM
The only engines I ever rotated forward were 3.1/3.4's.......
While you don't have to rotate the engine on a 3800, you do need the proper tool.......the setup I had was a spark plug socket ball joint, attached to a universal ball joint and then an extension.....this is basically a double ball joint setup, that can get into the craziest places...ball joints are smooth compared to regular universal joints, which tend to be be jerky.....
Actually, the hard part is not getting the plugs out, it's getting the plug wires off the plugs....they tend to "bake on" the longer they are on the plugs......it's hard to get your hand/boot tool, on the boot and twist them off.......
If I was replacing the wires too, I would just take a long pry bar, put it on the top of the heat shield on the boot, and give the bar a whack with a hammer....this snaps the top of the plug off with the boot(sometimes damages the boot/wire, so I only do this if replacing wires, too)......use a blow gun to blow out any porcelain chips that may surround the lower part of the plug(so they don't fall in when removing the rest of the plug with special tool).....then remove rest of the plug......simple and fast.....10 min max to remove plugs.....a trick an old timer showed me....now I'm the old timer....
Old 09-29-2016, 06:15 AM
A990 racer
Red face Re: 2000 Ultra Tune-Up - Loosen Motor Mounts
You guys are right, I was thinking of the 3800 in my 98 Lumina!
