Go Back   Automotive Forums Car Chat > Cadillac > CTS and CTS-V
Old 09-27-2016, 10:16 AM
jonnik jonnik is offline
Multifunction switch
2006 CTS, 3.6. My high beams sometimes come on when I activate the right turn indicator. I know that I am not pushing the lever forward, and I have read that this is not an uncommon problem. How difficult is it to change the switch? Has anybody done it and have any tips? I've seen some instructions and tips in a Cadillac forum, but I want all the information I can get.
Old 05-15-2018, 12:18 AM
tim_jackie2001 tim_jackie2001 is offline
Re: Multifunction switch
Ever get a resolution to this? I need to change my multi-function switch, but cant even get the plastics to come off.
Sorry forgot the car:
2008 CTS 3.6 DI
Old 05-15-2018, 07:23 AM
Blue Bowtie's Avatar
Registered Offender
Are you indicating that the plastic clamshell halves will not come off, or something else?
Old 05-15-2018, 07:32 PM
Yes the plastics covering the steering column won't release and I don't want to force them and break any retaining clips.
Old 05-15-2018, 09:11 PM
Question Re: Multifunction switch
OK, back to the drawing board..... I got the column shroud off and changed out the multi-switch, but it didn't fix my problem.
In a nut shell, I wrecked my car (in the front) and just got it back from the body shop. The DLR and low beams are fine, but blinkers, high beams and flashers won't. I can't find a blown fuse or a bad relay, I HAVE to be missing something.
Any help is very much appreciated, I really miss taking my baby out
Old 05-15-2018, 10:37 PM
Tech II Tech II is offline
You had an accident? Your insurance company pay the body shop? If yes, why isn't it taking care of the electrical problem?
But it sounds like your turn signal/hazard flasher module is the culprit....if fuses and relays are ok.....
Old 05-16-2018, 07:03 PM
Only had liability so repairs came out of my pocket. My husband had the same idea as you, but hasn't been able to locate the flasher module just yet. Can you tell me (for certain) where the flasher module is?
Headlights were a loose body ground on the radiator support, they're working now. But still dont have blinkers or flashers. I tested all the fuses with a DMM, and switched relays out with known good ones, and they all worked fine, so I think we've narrowed down the possibilities.
Old 05-16-2018, 08:56 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
There is no flasher module. It's all controlled in the BCM.
Old 05-16-2018, 09:21 PM
Stealthee, my diagram shows the output of the multifunction switch going to this module, not the BCM....
Old 05-16-2018, 10:37 PM
My son's given me all the information he can find on Alldata, it doesn't say anything about a flasher module only the bcm. Can I get one from a junkyard and plug it in or does it have to be new and reprogrammed by the dealer?
Old 05-17-2018, 03:30 AM
Here is a partial diagram I found for a 2006 CTS
Old 05-23-2018, 06:44 PM
Thanks, but I'm told the 206 is a different gen model and the same information won't work on a 2008. I did however find a replacement BCM on ebay.
Does anybody know if it still needs "programmed" or will plug and play work?
Old 05-23-2018, 06:51 PM
Stealthee's Avatar
It will likely have to be programmed, but I cannot tell you for 100% certainty.
Old 05-23-2018, 09:05 PM
You will not be able to take a BCM out of another vehicle and install it in yours, because it will have the VIN of the original vehicle it was in, and it won't match the VIN of yours, and thus there will be communication problems....
Sorry for the confusion of the year and diagram....this is what happens when you jump onto another post....
On a 2008, there is no flasher module, and the directionals and headlights are controlled by the BCM.....
A Tech II scan tool is essential to the diagnosis of the BCM, including inputs and outputs....
Since everything was working BEFORE the accident, how was it determined that it's the BCM and not a wiring problem?
