Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 09-25-2016, 10:39 PM
Tntgolden Tntgolden is offline
New to Panoz - brake and other help
Just bought 2006 GTS - New to Panoz so any or all help appreciated - has been stored for the last couple of years and am looking to get it back on the track for track days - was planning to change all fluids, bearings, front spindles, brake rotors and pads - brembro rotors avail for the front (expensive) but not the rears - was considering having Coleman making a set all the way around - any experience? they said they would save template does anyone have them saved? has anyone had them make hats? has anyone had them make spindles?
any other tips/tricks welcomed
Thanks!!
Old 09-29-2016, 09:46 PM
rioredstang rioredstang is offline
Re: New to Panoz - brake and other help
I need some rotors also. Maybe we could get a group buy.
Old 09-29-2016, 11:15 PM
Im sure they would work with us - they indicated once they make measurements they save them to make duplicates - not decided if I am going to have them make hats also - they can also make spindles - spindles are available from Panoz - I was planning to replace them - Panoz replaced them yearly on the school cars - the originals have been known to break which can be catastrophic.
Old 10-05-2016, 09:37 AM
panozracing's Avatar
panozracing panozracing is offline
I have broken many spindles. Definitely change them and track age etc.
I would not get coleman anything for the brakes unless you are not running 10/10ths. They are not nearly as strong as Brembo etc.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 10-05-2016, 10:46 AM
Brian - thank you - will replace the spindles ASAP - the brembro fronts are available ($475 a pop) but I can't find the rears - do you have a source or part number - I have been told to change the disc hardware at the same time and inspect the hats closely - love the picture - sexy beast! Thad
Old 10-10-2016, 02:01 PM
Front Rotors - 099226.39 & 099226.49 - 328x32mm
Rear Rotors - 095682.50 & 095682.60 - 320x28mm
Front Hat 90.129
Rear Hat 80.1047
Hardware per Wheel
Long Bobbin X20.30.26 - 8mm
Long Bolt A1.68.3J.105
Short Bobbin X80.20.08 - 6mm
Bolt Bolt A1.68.3J.103
Washer 05579320
Rear hub to hat upgraded hardware (recommended with safety wire...I break these) (also available from Panoz where I get them):
McMAsters - 92562A304 - MIL Spec Alloy Steel Socket Head Cap Screw, Cadmium plated, 5/16"-18 Thread, 1" L, Ms16997-80, Packs of 1
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 01-16-2017, 02:23 PM
bbenavitz bbenavitz is offline
I have purchased Coleman made rotors (just the ring not aluminum hat) twice and happy with the results. They give you a spec sheet to fill out and the turn around time is about 4 days at $250 each. I have the specs if you want to go this route. email is [email protected]
