Old 09-19-2016, 07:37 AM
joelwideqvist joelwideqvist is offline
Thickness of clear on decals
I'm getting some decals printed and has the option of 5 or 10 microns of clear on top. This sais nothing to me, could I get some guidance to wich I shall choose? What are the pros and cons?
Decals are for a motorcycle, small pieces - text and some graphic angles.
/Joel
Old 09-24-2016, 06:46 PM
CFarias's Avatar
CFarias CFarias is offline
Re: Thickness of clear on decals
Just from what you posted I would say it depends...
If the decals have sharp inside corners then the thicker clear should provide better resistance to tearing. Also use the thicker clear if you are not clear coating them. They'll hold up better to being handled.
If you plan to clearcoat them the thinner ones will be less noticeable than the thicker ones.
Old 09-25-2016, 01:17 PM
The 5th Horseman's Avatar
The 5th Horseman The 5th Horseman is offline
Hey Joel one feature of the thinner coating is that the step between the decal and the rest of the body will be less visible but because of that it will be more fragile. Considering that one micron is one thousandth of a millimeter i would suggest going for the thickest option ... or if you can try both perhaps...
Old 11-14-2016, 06:54 AM
Sorry for not responding to your help faster. Thanks, I went for the thinner ones as they are both rather small, not going over sharp edges and that I'm using clear on top of them.
/Joel
