Go Back   Automotive Forums .com Car Chat > Nissan > Altima
Old 09-17-2016, 07:09 PM   #1
jay11
Throttle body accelerator issue
Hi guys I just screwed up my car! Need some help!!
It’s a Nissan Altima 2005 2.5L
It was ok running car, only I had check engine sign due to code “P2135 Throttle/Pedal position sensor/switch A/ B Voltage Correlation”.
I thought before I spend couple of hundreds on changing the entire throttle body, let me try cleaning it up.
So I open the intake pipe and clean the air mass chamber and pipe, and the throttle body (without removing it). I thought it went pretty smooth. It had some decent amount of black grease which I cleaned up nicely using cotton soft cloth and “CRC 05078 Throttle Body” cleaner.
here is before and after.
I put everything back as it was. After I turn on the car, the accelerator is on! The effect is like somebody put a brick on the gas paddle!
In the opening/cleaning process, I did open (and reconnected) the electrical connector that was connected on the air mass body/pipe. Also the thin pipe that goes from the air body/pipe to the engine.
Although the engine error was most likely due to faulty sensor, but I thought I had nothing to lose, if cleaning doesn’t work, change the whole thing. But now with throttle going haywire, I can’t take it to auto store!
I really appreciate any help! Thanks!!
jay11 is offline   Reply With Quote
Old 09-18-2016, 11:19 AM   #2
Stealthee
Your worst nightmare
Stealthee's Avatar
Re: Throttle body accelerator issue
You need to do a throttle relearn
I found a Youtube video explaining the process
https://www.youtube.com/watch?v=afBmfKWDWZ4
Stealthee is offline   Reply With Quote
Old 09-18-2016, 11:35 AM   #3
jay11
Thanks Stealthee!
will try now and let you know.
Old 09-18-2016, 12:28 PM   #4
jay11
ok. I gave it a go. didn't work. could be because my engine was not on the normal operating temp. when i start engine the temperature indicate low.
Am I suppose to leave the engine on in order to increase the temperature? I mean at current situation it seems pretty hazardous as the throttle/accelerator is always on. and the tachometer read 3/4! it makes loud noise. i didn't dare to keep it on for more then few seconds.
also here
I see little different procedure than the youtube video
http://www.altimaforums.net/idle-rel...ay-t3398.html?
Old 09-18-2016, 12:45 PM   #5
Stealthee
Stealthee's Avatar
Definitely try that too. Good luck.
Old 09-18-2016, 01:22 PM   #6
jay11
yes other one didn't work either. main problem is probably the engine heat. my engine heat is not on the middle while i was doing it.
also, in one place I see it says, all the error code must be cleared in order to do this. is that true? as i already had a check engine on before all this... that also might be the problem.
BTW, is it safe to drive in this condition? at ideal/prk tachometer reads just under 3 and periodically jumps to 4
Old 09-18-2016, 04:00 PM   #7
jay11
ok here is the update.
I first reset the error code. check engine light went off.
then i let it run for few minutes. engine heated up to middle.
then i tried the process. this time i was able to follow it. the light blink and went solid as it says in the 7th step.
but after i turned on again, i see the problem remain. however it did reduce the throttle at ideal. before it ideal at 2000- 3000rpm now it ideals at 1000-1800rpm.
i repeat the procedure two more times no improvements.
here is a video (1 MB)
https://www.dropbox.com/s/w884zfr3akqsohf/Throttle.mp4
anybody with ideal relearn experience, please let me know.
thanks again!
