Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-14-2016, 11:39 AM
charles546 charles546 is offline
fuel pump issues
My grandson has 1991 w150 pickup which died all of a sudden.had no fuel pressure so put in new pump and still wont start.truck sat for two months before i went to get it.only has 10.84 volts at harness to fuel pump.swapped relays no change.what gives thepump its ground?any help would be appericated. Thanks charles
Old 09-20-2016, 06:02 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: fuel pump issues
Does the pump run?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-20-2016, 07:48 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Most fuel pumps don't get a full 12 volts. Doing so causes overfueling, so the voltage is probably not your issue.
On Chris' question it is definitely valid and needs answered. If it doesn't run, try running direct power to the pump to see if it runs.
