Go Back   Automotive Forums Car Chat > Cars in General
Old 09-11-2016, 06:44 AM
Pickngrin Pickngrin is offline
Is this rim damage unsafe or just cosmetic?
Hi-
I'm looking for a second set of rims (for snow tires) for my Saan 9-3. Someone on Craigslist is advertising a set of 4, with 1 damaged (see pic). Does this appear to be unsafe or just cosmetic?
Thanks
PnG
Old 09-11-2016, 04:05 PM
MikeCStig MikeCStig is offline
Re: Is this rim damage unsafe or just cosmetic?
Don't risk it. That big chunk missing looks like it might be problematic as far as sealing a tire around it.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 09-11-2016, 09:28 PM
Thank you for your input. I will not pursue those.
Old 09-16-2016, 04:59 AM
jasongraygits jasongraygits is offline
I suggest you not to take risk in this matter it seems like it is unsafe.
Old 09-16-2016, 01:07 PM
Copytech99 Copytech99 is offline
^^^ Great advice.......Pass.
Old 09-16-2016, 01:17 PM
I appreciate all of the advice. I did not follow up on those rims. I'm glad that I asked.
Thanks again.
Old 09-20-2016, 09:59 PM
iracing iracing is offline
You definitely have to change a new rim.
See how a piece of the rim was missing? this is where rims hold tire bead in place. with that missing tire pressure will drop.
In addition, I saw burn marks on the edge of your rim. You must drove a substantial distance after flat tire. Now the rim has lost its strength due to heat. Any rim retailer would tell you to replace it ASAP.
Old 09-20-2016, 10:23 PM
Thank you. These are not my rims. I saw them advertised on Craigslist and did not investigate further after the helpful advice I received here.
