Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 09-01-2016, 05:41 PM
Jmrh2000 Jmrh2000 is offline
Symbol lit on dash not in manual
Hi. I have a 2014 Hyundai Sonata that periodically will not start unless put into neutral. When it doesn't start it shows a symbol that is not in the user manual. It looks like a red steering wheel with an exclamation point, also in red, to the right of it. Does anyone know what the symbol is?
Old 09-01-2016, 07:18 PM
MikeCStig MikeCStig is offline
Re: Symbol lit on dash not in manual
A picture of the light would be helpful. From your description it sounds like maybe a reduced power/ limp mode warning light, or maybe a brake warning light, but I can't really narrow it down unless I see it.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 09-01-2016, 08:23 PM
aleekat aleekat is offline
I don't think this is stopping you from starting your car. Some other issue.
Electronic Power
Steering (EPS)
Warning Light
(if equipped)
This warning light illuminates:
• Once you set the ignition switch or
the Engine Start/Stop button to the
ON position.
- It remains on until the engine is
started.
• When there is a malfunction with
the EPS.
In this case, have your vehicle
inspected by an authorized
HYUNDAI dealer.
Post back, that's what makes Forums Work.
Old 09-01-2016, 09:09 PM
That's the symbol. It wasn't showing up under dashboard symbols. At a loss to why car intermittently not starting. When doesn't start sometimes will do so shortly after, others up to 1 hour & 45 minutes. After that I read manual pretty much cover to cover & found how to start it after 1st fail try, drop to neutral & push button again. Works great! No indicator lights come on when driving at all. Just hope not damaging car by my work around.
Old 09-01-2016, 09:12 PM
Thank you all for your great responses! If anyone has ideas on the start tissue, let me know. Also if you think I am damaging car by neutral start, I also want to know that!
Old 09-02-2016, 12:05 PM
If that's what it is... I'm sorry, but I have to post the rhetorical question; what exactly was wrong with hydraulic power steering? The wheel is easy to turn, yet you still get feedback through the steering wheel, and I'm starting to question the reliability of electric power steering systems.
Old 09-02-2016, 05:24 PM
There's nothing wrong with the EPS. Light comes on turning the key on. Once car is started light is out. It's working as it's suppose to.
