Old 08-31-2016, 06:26 AM
Backwoods123 Backwoods123 is offline
Starts weird when wet out
How's it going guys, I'm new to the forum... My name is josh.... I have an S-10 2003, 2.2L, 130,000, truck has never given me an issue besides the starter a couple years ago but about 2 and half months ago I get in my truck in the morning to start it and it started but seemed to be a sluggish hard extended start, it didn't in the morning that week maybe 3 times... And the next week, then stopped for about a month and then one morning it did it again... And it's been doing it the pat couple mornings... And k notice it seems to to do it when it's wet or moist out in the morning otherwise any other time it starts right up in 1-2 seconds... I need help with this one
Old 08-31-2016, 08:13 PM
MikeCStig MikeCStig is offline
Re: Starts weird when wet out
What you're describing isn't unusual at all. It just your truck showing it's age, nothing to get too alarmed about. The seals in various parts of the ignition system are probably wearing out and allowing moisture in. I'm thinking a tune-up would be a good idea. New plugs, wires, and distributor cap (if your truck has a distributor, I can't remember) will help, and also just going through the entire ignition system and replacing the seals.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
The Following User Says Thank You to MikeCStig For This Useful Post:
Backwoods123 (09-01-2016)
Old 09-01-2016, 06:31 AM
Appreciate the advice man
Old 09-01-2016, 06:52 PM
Blue Bowtie's Avatar
Registered Offender
My '96 has about 210K on the 134-inch four-holer. I've had spark plug wires suffer insulation breakdown, causing a similar symptom.. It's also a good idea to clean the coil packs and apply dielectric grease to the boots at the connection points. Of course, the spark plugs should have been changed about 30K ago, and it they were not replaced with OEM platinums their life expectancy is lower. Back in the day, "regular" plugs that lasted 20,000 miles were about due for change. It you installed regular old steel plugs at the 100,000 mile change interval those "new" plugs could be about done by now.
