Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 08-28-2016, 09:08 AM
hoonch hoonch is offline
AC component help - Jeep liberty 07
Hi all,
Would any of you know what component is under the hood.
Highlighted in green - It's connected to the AC compressor and I think it's giving it power. Its the black connecter and Its a bit loose, causing my AC to stop working when it it, so I need to order the same part but no sure of the name.
Would be great if someone could help me out.
Thanks!
Hoonch
Old 08-28-2016, 09:44 AM
brcidd's Avatar
brcidd brcidd is offline
Re: AC component help
That would be called the coil connector for the a/c compressor- but I highly doubt that is your issue- I've been doing a/c for thirty plus years and never seen one go bad-- you can unplug it and examine it to see if there is noticeable damage, burns, melts etc-- do the wiggle test- see if it goes on/off/on etc-- if so , just bending the pins in the connector would suffice...
Even with a new connector, you will have to splice it in-- so why not splice around it entirely for the meanwhile--if you are sure it is bad....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
hoonch (08-28-2016)
Old 08-28-2016, 10:40 AM
Smile Re: AC component help
Hi Brcidd, thanks for the very quick reply and great info+advice!
I'll check the pin on the connector as you mentioned.
Just to note: the AC seemed to stop working after I pushed the old car to around 95 mph ( it always seems to not get as cold if I push the car hard ) but this time it stopped all together.
I showed someone at the gas station and they wiggled it around till the compressor started spinning. So, from your expertise, hopefully it's a bent pin that can be pushed back easily, I'll take a closer look!
Thanks again!
Hoonch
Tags
a/c , component , compressor , connecter , engine
