Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 08-26-2016, 01:32 PM
Vicraiderz Vicraiderz is offline
Engine swap
Im wondering if I can transfer parts 82 chevy el camino 305 to a 93 chevy 350 motor . Because I heard different storys .
Old 08-27-2016, 11:09 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Engine swap
Not sure I quite understand ... you want to put a '93 TBI engine into an '82? That can be done, but you would need to get the proper Quadrajet intake for the '93, with the 72-degree angle middle bolts that are found on all '87-'95 small block engines. An intake from a 1987-1988 Caprice would work.
You would have more problems putting that '82 engine into a '93 as there are no factory TBI intakes for the older heads that have 90 degree bolts for all locations.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
