Old 08-26-2016, 01:00 PM
CFarias's Avatar
CFarias CFarias is offline
Has Anyone Successfully Removed the Chrome/Metal Plating from the New Aoshima Kits.
Howdy from Texas,
On the latest Aoshima Lamborghini's I'm having trouble removing the metal plating from the rims. My usual standby of Super Clean is not working.
What I'm wondering is has anyone has been able to strip the metal plating of the Aoshima rims. I have the Aventadors, specifically. I know that there are other solutions such as brake fluid and alcohols, but I'm wondering what method has been used successfully on those wheels.
Thanks in advance.
Old 08-26-2016, 09:12 PM
nascar49's Avatar
nascar49 nascar49 is offline
Send a message via AIM to nascar49 Send a message via Yahoo to nascar49
Re: Has Anyone Successfully Removed the Chrome/Metal Plating from the New Aoshima Kits.
Originally Posted by CFarias View Post
Howdy from Texas,
Thanks in advance.
I have no issues using the purple cleaner removing the new chrome from Aoshima.
Which purple cleaner are you using?, the real stuff?, or the knock off brand, I ask because a lot of guys call the knock off brand the Super Clean too, white or purple bottle?
You could always try 91% isopropyl alcohol.
Pheedens Garage on Youtube
https://www.youtube.com/channel/UC4j...J8vUP1ZaHP32ig
Old 08-26-2016, 11:59 PM
CFarias's Avatar
I'm using the real Super Clean in the purple bottle, but I think I found the problem.
The Super Clean I was using has been used quite a bit and maybe it sort of went stale. I replaced the old liquid with new liquid and, even though the Aoshima plating still took longer than usual, it worked just fine. I also tried using the alcohol and this worked at about the same rate as Super Clean. It seems both solutions work on the Aoshima plating.
Lesson learned, keep your liquids clean.
Thanks for the help.
Old 08-29-2016, 04:17 PM
corvettekid_7684 corvettekid_7684 is offline
Did you try bleach?
Old 08-29-2016, 04:37 PM
CFarias's Avatar
I have not tried bleach but the alcohol did the trick. If you've tried bleach any issues with getting it on your clothes?
Old 08-30-2016, 12:55 PM
Well, you certainly don't want to get it on your clothes...
