Old 08-24-2016, 03:53 PM
Checkerknight Checkerknight is offline
Installing an aftermarket radio
Hello everyone, I am having some power issues upon installing an aftermarket radio into my 1971 Plymouth Fury. I was able to get the old radio out but the car has only a single wire for constant and an ignition power.
I tried just wrapping and taping the new radios ignition and constant power wires to this but it causes the radio to be connected to dome light power and whatnot. (Ex. radio only turns on when door is open, close door radio will turn off with lights, and turning headlights on will cause radio to reset.)
I was told that I should try just connecting the ignition wire to the connection showed in picture, and get more wire in order to run the constant directly into the battery. Any ideas?
Old 08-26-2016, 07:19 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Installing an aftermarket radio
you obviously have the wrong wire(s), check them with a multimeter. Also, run the black ground wire from the radio straight to some metal behind the dash.
Old 08-26-2016, 06:10 PM
I am unsure as to what you mean by wrong wire. I'm not using a kit or anything I'm just looking at the wires coming out of the radio and car itself. As far as the radio goes, the constant and ignition and ground have to be plugged in regardless correct? All the other wires in the back of the radio are for speakers, which this car only has one so the majority of them are taped off.
Old 08-28-2016, 04:32 PM
Also I need some advice on getting a radio mounted into this car. I have been unsuccessful in my search to find a dash kit for this car.
Old 08-29-2016, 07:34 AM
Audio Guy
You are trying to mount a DIN sized rectangular face chassis into a space made for a radio with a shaft on each side. I am uncertain if you will ever find a mounting kit for this car, you might have to fabricate something.
As far as the wiring goes, you will need a multimeter. Set it to volts, put the black lead on metal behind dash and check each wire carefully with ignition on and off, lights on and off, etc .. to determine which wire is what.
Old 08-29-2016, 03:49 PM
Now your talking the wires from the back of the radio i assume right? As I stated the only thing coming from the car is the piece that I am holding. The 2 to the side of the picture go to the speaker. So you're saying to hook up the radio and then check all the speaker wires from the radio?
Old 08-30-2016, 07:35 AM
Audio Guy
no, not the speaker stuff and not the wires from radio. You may need a manual for the car. The ground from the factory radio may just be the metal to metal contact. You will need to connect the black wire from the new radio to metal behind the dash. If you don't, it will ground thru the antenna and may damage it. You can run your own power wires if you want .. find a spot on the fuse block that has constant 12V and another one that has 12V when power is switched on. This might be a better option for you.
