Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 08-11-2016, 10:23 PM
jaybowblue jaybowblue is offline
Toyota yaris misfire/coolant leak
I'm experiencing two issues with my Toyota yaris.
1. 3rd cylinder misfire
a. replaced sparks and coil but still misfiring
b. seems to be a bit rough when starting but generally drives fine without issue.
2. overheating
a. seems to be an antifreeze leak, right under the engine, i can't quite tell where its coming from other than that
b. I just had the headgaskets replaced, i don't see any over white smoke in my tailpipe and i don't typically smell any antifreeze. Had the guys who did my headgaskets run a compression test and it came out fine
Any ideas on where the antifreeze is leaking?
What do check next for misfire? it has been suggested i consider replacing the fuel injector.
Old 08-11-2016, 11:05 PM
Re: Toyota yaris misfire/coolant leak
Felt like i should add that i had the water pump replaced when i had the gasket done in case this was a suspected coolant leak location.
Old 08-13-2016, 08:20 AM
The random misfire is still unexplained however the coolant leak is coming from a missing bolt in the back passenger side of the engine.
