Old 07-28-2016, 03:11 AM
ganhanugrah's Avatar
ganhanugrah ganhanugrah is offline
Car Audio Settings - HPF vs. LPF?
The following is the current configuration in my F150:
- 4 Kicker KS68 Speakers
- Kenwood 1000 Watt Class D Mono Amp
- 12" Rockford Fosgate P3S12 (sealed enclosure)
Given my current setup, what do you think I should set my HPF and LPF to? As of right now, they are both turned off and it sounds great. I was just curious as to if there's a better setting I could be utilizing.
Old 07-28-2016, 07:09 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Car Audio Settings - HPF vs. LPF?
I am assuming your sub is run off of the class D amp and the 4 speakers are being run from headunit. Turning the lpf on and set to about 70-80 Hz will block the sub from playing frequencies above that - might make it sound a little better.
Tags
settings
