Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 07-21-2016, 12:24 PM
ulremember ulremember is offline
92 Estate Wagon no power 5.7 off idle TBI
Good day. My issue is this: car idles great. As soon as i give it a bit of gas in drive, iget hiccups and no power. I have changed, injectors, map sensor, tps and the fuel pump ( about 2 years ago Autozone brand)
My timing is set @ 0 degrees. When i changed the injectors, i did not mess with the regulator.
Any suggestions as to where to look next. Car has 210,500 mile and when she was not hiccuping, RUNS GREAT and pretty good on gas.
Thank you in advance.
Blessings
Thanks to all!
ulremember aka Chuck Jr.
Old 07-21-2016, 05:53 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 Estate Wagon no power 5.7 off idle TBI
Start by checking fuel pressure, 10-13 psi, change the fuel filter this is where to take the fp readings anyway. If the the tps is the adjustable type, make sure it is set right, timing was set with reference wire disconnected, correct?
