Old 07-21-2016, 11:07 AM
sadpontiacdriver sadpontiacdriver is offline
A/C problem. Panel or actuator?
The car has dual zone control sliders driver/passenger. The DRIVER'S side does not turn cold or hot, it stays the same unless you keep pressing on the slider.
I popped the dash cover and looked behind the panels to see the actuator. It IS working and it turns when you move the slider, but it turns back to neutral (center) position once you let go of the slider.
It doesn't matter which way you move the slider; up (hottest) or down (coldest) the actuator will turn to the correct position but it returns back to center position.
Would this be a problem with the Control Panel or the Blend Door Actuator?
Old 07-21-2016, 01:04 PM
brcidd's Avatar
brcidd brcidd is offline
Re: A/C problem. Panel or actuator?
I've replaced dozens of actuators on "W" cars- never a control head (you say panel) so I'd play the odds..but I will say they generally fail and quit working altogether due to a cracked gear- take your actuator apart, is gear cracked? there is a seller on Ebay who sell new steel gears.....for 1/4 th the price of a new actuator...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
sadpontiacdriver (07-21-2016)
Old 07-22-2016, 08:39 AM
Tech II Tech II is offline
If it stays in place as long as you hold the slider, I'm thinking control head......check the numbers on the actuators for both sides...if the same swap them, and see what happens....
The Following 2 Users Say Thank You to Tech II For This Useful Post:
sadpontiacdriver (07-27-2016)
Old 07-22-2016, 03:06 PM
Update.
It wasn't the actuator. I replaced it and the issue remains. So eBay, here I come.
