Old 07-21-2016, 07:03 AM
gg315 gg315 is offline
98 Accord Lx 3rd brake light
Hi . I just replaced the bulb for the 3rd brake light. Brake light indicator on the dash is still on. Is there something wrong or is there something else I need to do. thank you
Old 07-21-2016, 07:48 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 98 Accord Lx 3rd brake light
Is this the red brake light on the dash that stays on? There was a TSB for the float on the master cylinder cap being stuck down, causing the light to stay on. You may check that, or the fluid may be low in the master cylinder. If it's low, you either have a leak, or you need to check your brake pads. The light will also come on with the park brake. It's possible there is a problem with that switch also.
Old 07-21-2016, 10:10 AM
somick's Avatar
somick somick is offline
+1
My brake indicator light often comes on. Especially when the car is cold. When it bothers me too much I wash the strainer with brake fluid and it goes away for some time and then it comes on again.
Check your brake fluid level!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
The Following User Says Thank You to somick For This Useful Post:
gg315 (07-22-2016)
Old 07-22-2016, 06:09 AM
Thank you I will check . I should also note that the brake lamp light doesn't come on when I start the car, only when I step on the brake thanks again!
Old 07-22-2016, 09:13 AM
somick's Avatar
Check it ASAP! It might be low on brake fluid.
Sam
