Go Back   Automotive Forums Car Chat > Chevrolet > Tracker
Old 07-18-2016, 08:08 PM
LadyPamela LadyPamela is offline
2002 Chevy Tracker problems
i have a 2002 Chevy Tracker v6 that has been causing me issues for the past 30days. it has a NEW battery, NEW alternator (2nd one in fact since 1st one was bad), and NEW belts. the battery is still NOT holding a charge. one day the car starts fine and the next it needs either a jump start or a put on a charger overnight. after replacing the battery and alternator a new issue has reared. if you drive over 50MPH the car starts to make a thumping sound and then the motor dies requiring a tow. nothing is broken/loose/missing so the source of the sound cannot be located. i'm at my wits and $$ end. no one here can figure out the issue with this car. i'd be happy to take any suggestions.
Old 07-19-2016, 08:50 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2002 Chevy Tracker problems
Sounds to me like you have a current draw that is killing the battery. Look for the obvious, like a glove box lamp staying on, radio, other lamps. Anyhing plugged into a power outlet. If all those check ok, then further diagnosis will be needed to find the draw. A multi-meter can be set in series between the negative battery cable and negative batter terminal to see the amount of current being drawn. On yours, I would expect to see less than
20mA, probably closer to 0. As far as the noise, hard to tell from here, is there oil in the engine?
Old 07-19-2016, 01:33 PM
Thank you for the suggestion! I'll get that checked. I don't see anything staying on or plugged in but I'll have it checked. As for oil, yes it was just recently changed (April or May) and the dipstick reads full.
