Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-16-2016, 12:38 PM
STONEBOSS1 STONEBOSS1 is offline
Hvac vacuum line--2000 regal ls/digital climate control
Located the dreaded broken plastic vacuum line that supplies vacuum to operate airflow direction to my A/C. It broke off below the coupling which is located just below the main fuse box. I cannot find the other broken end, so as I can connect a hose in between both broken ends. I've read that it leads back behind the battery thru a main harness and then back thru the firewall. I cannot find the other end or locate which harness it runs back into. A pic or a detailed description would be a great help. Thank you.
Old 07-16-2016, 04:20 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Hvac vacuum line--2000 regal ls/digital climate control
Under the battery tray-- leads to reservoir in front of front left wheel....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Old 07-16-2016, 06:38 PM
Thank You brcidd for your reply. I will look in the area you're referring to and reply back with results. Thanks again.
Old 07-20-2016, 03:16 PM
Unfortunately, I'm not having any success in locating the other end of the broken HVAC vacuum line. I removed the battery and tray it lays on, also disconnected the RH headlight. Checked and looked within any harnesses within the general area of the battery...still unable to locate. In addition I looked for the reservoir on front left wheel. But to be honest...I really am unfamiliar of what that reservoir looks like. A pic of the reservoir would be helpful so as I can make that the starting point and backtrack to the open end of the vacuum line. Thank You!
Old 07-20-2016, 04:47 PM
brcidd's Avatar
Its behind the plastic inner left front wheel lining- turn steering wheel all the way to the right and go under front and take liner loose directly in front of wheel. This will expose the reservoir...and the hose dangling from it..
'99 GMC Yukon
Old 07-20-2016, 09:39 PM
Tech II Tech II is offline
An old trick is to disconnect the vac line from the HVAC controller, and if you are a smoker, blow smoke through the line, and look for smoke emanating from the disconnect....if you don't smoke and have access to an air line, blow air through it and listen for the disconnect.....
