Go Back   Automotive Forums Car Chat > Buick > LaCrosse/Allure
Old 07-15-2016, 11:27 AM
Rawlinson491 Rawlinson491 is offline
ABS & Traction Control Sensor
2008 Buick Allure My ABS and TC lights are coming on when braking/turning No codes are shown when checked with a Black & Decker Smart Scan Any suggestions Thanks Steve
Old 07-15-2016, 03:55 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: ABS & Traction Control Sensor
Are you sure that scanner has the ability to read ABS codes? It may only read ECM or "P" codes. ABS codes are "C" codes. You probably have a issue with one of the speed sensors harnesses, but without a code, it's a complete, but educated, guess.
Old 07-15-2016, 04:25 PM
Yes scanner does not read the codes !! Interestingly I noticed my right front tire was under inflated Corrected it and problem seems to have gone but that may just be a coincidence ?? - I tried to duplicate the problem by hard braking and turning the wheel - No lights !! Any thoughts?
Old 07-15-2016, 08:42 PM
Tech II Tech II is offline
Yes, an underinflated tire can cause this......also if you damage a tire, and replace it with a different brand, or a new tire and the other three are worn, the circumference difference can be enough to alter the rotational speed of the tire in comparison to the other three....
Old 07-16-2016, 11:54 PM
Rasp Rasp is offline
On a side note the speed sensor harness has been a problem for me a couple of times. The design is pretty bad. When you turn your tires the wire that it is connected to also bends with a turned tire. After time you will get a short on that wire harness.
Old 07-17-2016, 09:25 AM
Blue Bowtie's Avatar
Registered Offender
Excellent point, Rasp. I'll second that. It happens on several body platforms as well - H-bodies, N-boies, W-bodies, and the minivans.
Old 08-21-2016, 12:04 PM
You get an open, not a short...
Old 08-24-2016, 10:46 AM
Well all I know is something super bad happens when it is open or short.
lol
