Old 07-13-2016, 04:19 PM
El Gato27 El Gato27 is offline
Gear Oil Recommendation for 2007 Corolla
Planning on changing the gear oil on my 2007 Toyota Corolla. I’ve used the regular Valvoline in the past but I have always wondered about the Royal Purple gear oil. It is more expensive and I was wondering if it would make shifting much smoother or if I would even notice a change. Willing to pay extra if there is a noticeable improvement in shifting.
Motivation here is that I am planning on teaching my daughter how to drive standard and would like the shifting to be as smooth as possible.
Thank you.
Old 07-14-2016, 10:36 AM
MikeCStig MikeCStig is offline
Re: Gear Oil Recommendation for 2007 Corolla
All I've heard about royal purple is that it lasts longer and provides better protection to moving parts. As far as smoothing out the shifts you may want to take a look at the linkage and replace any worn parts.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 07-14-2016, 12:35 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Any synthetic gear oil of the correct weight will likely make the shifting noticeably smoother. Years ago when I still had a vehicle with a manual transmission I went with Valvoline synthetic to better handle the heat from track use. Right away I noticed the transmission slid in to gears smoother than before which was a welcomed side benefit.
-Rod
