Old 07-04-2016, 01:27 PM
yeahbutstill yeahbutstill is offline
Question Transmission problems on a 2001 taurus
ok my taurus wont shift drive and is leaking fluid. what could it be?
Old 07-05-2016, 06:49 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Transmission problems on a 2001 taurus
There are hundreds, if not thousands, of possible answers to your question. More information will be required to give you any sort of realistic answer.
Are you trying to say that your car will not shift out of drive, or it won't shift gears when in drive? Have you checked the transmission fluid level and condition? What color is the fluid that is leaking? Are any of the fluid levels indicating less than full (washer solvent, antifreeze/coolant, power steering, transmission, engine oil)? Do you have a raw fuel smell around the car or under the hood?
-Rod
The Following User Says Thank You to shorod For This Useful Post:
yeahbutstill (07-10-2016)
Old 07-08-2016, 09:51 PM
sorry
it won't go forward,it does have reverse. level/color fluid is good
Old 07-09-2016, 10:07 AM
MikeCStig MikeCStig is offline
That's a little different from what usually happens to the older Taurus transmissions. Usually it starts doing things like randomly slipping between gears (feels as if it went into neutral) or starting in second gear and refusing to shift, and it happens disturbingly often. Did it do anything like that before it failed?
There is a chance (cross your fingers) that it's not a transmission problem, but a shifter cable problem. That would be a much cheaper and easier fix so look into that before you do anything as drastic as tearing the transmission apart.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 07-09-2016, 12:17 PM
shorod's Avatar
SHO No Mo
Have you tried shifting down to '2' or '1' to see if it will move forward when manually selecting those gears? Does the engine sound like it's loading at all when a forward gear is selected or does it rev freely like it's in Park or Neutral? If it seems to be loading, make sure the car will roll when in neutral and it's not a situation of a seized brake or stuck parking brake. Parking brakes often hold better from going forward than from rolling backward.
-Rod
Old 07-10-2016, 12:15 AM
before this sometimes it will take a few seconds to gear on reverse
