Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-30-2016, 01:20 AM
Pasadeana Pasadeana is offline
2002 Olds Bravada electrical problem
Went to install new stereo system and now nothing electrical inside the cab works. The Truck starts up no problem and drives. Just no power to windows, locks, interior lights, no stereo, no air/ac. The instrument panel/gauges work but the light doesn't. Checked Battery cables, fuses, and unhooked onStar (not used by us or previous owner). Can someone please help? Thank you.
Old 06-30-2016, 09:07 AM
aleekat aleekat is online now
Re: 2002 Olds Bravada electrical problem
Had to be something during the stereo install. You'll have to back track and double check connections, pulled connectors, etc.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Pasadeana (06-30-2016)
Old 06-30-2016, 09:08 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I bought the install kit, with the special adapters when I put another radio in mine.
The Following User Says Thank You to Chris Stewart For This Useful Post:
Old 06-30-2016, 09:42 PM
Thumbs up Re: 2002 Olds Bravada electrical problem
We found the problem. I turned out to be the instrument panel battery in the fuse box under the hood. It tested fine with a voltage meter. Retested it with a test light and it was bad. Anyways, we found the problem. Thanks for your comments in helping me with my problem. Much appreciated.
Pasadeana
The Following User Says Thank You to Pasadeana For This Useful Post:
Chris Stewart (07-01-2016)
Old 07-01-2016, 10:42 PM
AF - Advisor
Thanks for the update.
Tags
2002 , bravada , electrical , oldsmobile
