Old 06-27-2016, 10:01 PM
slightlysubliminal slightlysubliminal is offline
01 Dodge Grand Caravan,one light works, the other doesnt; replaced FCM and still DOES NOT work
Hello all,
Recently started working on a 2001 Dodge Grand Caravan that was given to me and noticed the lights malfunction. After much research I found that one daytime light working and the other not, and then switching when turning on headlights or brights is a common issue and many resolve the issue by replacing the Front Control Module. I did this as well as replaced the main computer but the light issue is not fixed and I have created a new problem it seems: my van now runs very rough and it is throwing codes for the throttle position sensor claiming to not get enough power and something else to do with my 5th cylinder. PLEASE HELP!
Old 07-02-2016, 03:40 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 01 Dodge Grand Caravan,one light works, the other doesnt; replaced FCM and still DOES NOT work
Not familiar with DLRs (your daytime lights?). I take it you changed the bulb, inspected/cleaned the socket, checked for voltage at the socket correct? I'm sure you read about slightly twisting the contacts on the FCM to make better contact. Not sure which are DLR contacts.
If you changed the PCM (your main computer?) and now you have a rough running engine you either damaged a contact/wire when you installed it or the PCM you installed is bad. Why did you change it?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Tags
caravan , daytime , grand , headlights , lights
