Old 06-23-2016, 11:12 PM
NHRA's Avatar
NHRA NHRA is offline
idle haywire when you turn on AC
2000 blazer 4.3 2 wheel drive auto trans ...........anyone ever seen this problem?
idle haywire when you turn on AC, idle jumps up 500 to 1500 rpms
had it at 2 shops don't want to mess up when it goes to the shop
have had the smoke test done, replaced ivac , tps ,temp sensor, mass air flow,
first time it went to the shop, they told me the intake gasket was bad had that fixed
shows no codes? now as soon you turn the ac on 80% of the time it will act up.
and even if you turn it back off it still acts up for along time.
ive done some research but cant find my problem, ive read that the reveits on the Throttle Body get loose but mine are fine, the mech from the shop said it could be the ECM?
thanks guys <<<<<<<<<<
Old 06-24-2016, 07:58 PM
NHRA's Avatar
Re: idle haywire when you turn on AC
anyone?...........................cheers
Old 06-26-2016, 06:01 PM
NHRA's Avatar
where have all the good mech gone? this site is dead use to be help everywhere now I see no one? just saying
Old 06-28-2016, 09:27 AM
NHRA's Avatar
Angry Re: idle haywire when you turn on AC
ok after 4 days no replies?...............sites not what it use to be ....delete my act<<<<<<<
Old 06-28-2016, 09:51 AM
aleekat aleekat is offline
I'll ask the obvious. Had any a/c work done lately?
Post back, that's what makes Forums Work.
Old 06-28-2016, 10:52 AM
NHRA's Avatar
no I haven't just one day the idle started acting up and I found out it did it when you use the ac, but would still act up after ac was turned off for awhile then would be ok again
till you turned the ac controls to on....................thanks<<<<<<<<
Old 06-28-2016, 03:08 PM
maxwedge maxwedge is offline
A990 racer
Make sure no has fooled with the base idle on the throttle body, also a scan with a good scanner will allow you to look idle control activity, I assume no codes? Also make sure no air is getting in behind the maf.
Old 06-28-2016, 07:58 PM
NHRA's Avatar
no one has touched the the idle and right no codes
new maf no leaks had mech do smoke test with no leaks................thanks
