Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 06-23-2016, 11:03 PM
BIG JIM SLADE BIG JIM SLADE is offline
01 sephia a/c compressor pulley
Is the a/c pulley supposed to spin freely ? If it sticks in spots / feels like grinding internally, can you just switch the pulley/bearing/shaft bolt. How would it be done ?
Thank you.
Old 06-24-2016, 09:05 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 01 sephia a/c compressor pulley
Yes, you can replace just the pulley bearing- just did one on a jeep wrangler yesterday- Autozone had the bearing in stock ($17.99) - trick is to be able to get to front of compressor where you can use a pair of snap ring pliers to remove pulley snap ring (and clutch driver and bolt first). Then go to your buddy's house and use his arbor press, to press out old bearing and press in new one-
Oh, and if you can't get near front of compressor, then you have to remove it and do the work on your work bench. Sometimes it can be a PITA.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-24-2016, 09:07 AM
brcidd's Avatar
Yes, you can replace just the pulley bearing- just did one yesterday- Autozone had the bearing in stock- trick is to be able to get to front of compressor where you can use a pair of snap ring pliers to remove pulley snap ring (and clutch driver and bolt first- watch for shim- don't lose it!). Then go to your buddy's house and use his arbor press, to press out old bearing and press in new one-
'99 GMC Yukon
